I am running a daylight study for the UDI, and have used this script many times, but I have recently been getting an “AssertionError” on the Annual Daylight Metrics component after I have run the analysis. I am not sure what is causing it and have triple checked all of my geometry. I screenshot of the error message is below. Any ideas how to fix this? Thanks.
It seems that you have more than one analysis result file for this study (it looks like at least two .ill files are being added according to the simulation report).
If you can upload a definition that recreates the issue, we can get a better sense of what is going wrong.
I am trying to add a frit pattern through the perforate.cal function. I am able to successfully do it in legacy honeybee, but when I plug the perforate.cal material into the HoneybeePlus_Honeybee Surface Component I get the assertion error:
