Assign glass materials using honeybee apertures by ratio
Dear all,
I am wondering if there is a way to assign materials to a glass surfaces obtained by using HONEYBEE APERTURES BY RATIO components. I don’t think there is a specific component to do that. I’ve found a workflow in the old forum (attached) but it doesn’t work with the latest version.
Any idea?
Angelo
Try the HB_ApplyWindowConstr component under the HB_Energy tab, group 1.
Thanks @AbrahamYezioro ,
Do you need to re-apply also the construction set to the opaque wall before connetting the faces to the HB ROOM?
Thanks a lot.
Angelo
No, you don’t.
You don’t need to deconstruct the room either. You can connect the rooms as they are to the HB_ApplyWindowConstr.
