This may be a stupid question, but I can’t find the answer anywhere.
With the construction sets, it basically presumes all exterior walls are the same, all interior walls are the same, all windows are the same. How can I assign different wall constructions, different window materials? I see it’s possible to assign different constructions when I use faces, and when I use the HP aperture for windows. But what if I want to use the HP apparture by ratio? It seems that the only way to assign a window material then is by using the construction sets, but then the window type is the same for all windows.
