First of all thank you for a very nice workshop! I learned a lot.
Regarding the workaround to be able to use BSDF idfs through honeybee legacy: How about that the component not only searches the EP contruction library, but also the additional strings input, before displaying an error for allegedly missing EP constructions, matrices, etc?
Is HB currently able to import BSDF IDF files from Window LBNL?
I’ve been trying to import a BSDF IDF file exported by Window in HB, but it was not succesful. My screen is a complex shading system. It is a perforated screen placed 0.60m in front of a double clear glazing system. How can I assign the bsdf idf file (perforated screen + glazing) to a facade? Is it possible to set the bsdf idf file to a childsurface by using an EPConstrucion?
Many thanks in advance. I’ll appreciate any help you could give me.
