Hi.
I’m trying to do wind analysis on several highrise buildings. As I Know the wind speed is in direct relation with the height. as you see in the attached image. I wanna know if I can give a variable inward wind velocity along the height of the building cause as I see there is only one input available as the Wind Speed in “Butterfly-wind vector” component that I could just assign one number to it and as it says this number refers to refrence wind height.
Is there a way that i could somehow give a domain of numerical data as the wind speed input?
