Hey guys,
I am in trouble with the preparation of the model for the energy analysis with honeybee. To better explain the design concept i will attach a jpeg file and the .gh file. The idea behind is quite simple: i have an adiabatic room, so no sun exposure, and a surface expose on the south. This surface is discretize by nine opaque’s panels, A in the jpeg file, and three glass surfaces, B.
I set up the model in this way:
five adiabatic surface;
two different type of materials for glass (B) and opaque part (A) of the surface.
The problem seems to be after the Honeybee Create Zones component. If i give the same material, glass, to hall the surfaces it works fine.
I cannot identify the problem with this process. Can someone help me?
Thanks in advance to all of you guys!
Best
Angelo
test room_energy analysis.gh (647 KB)
