Hello there!
I have created a series of vectors mapping out sunpaths in london during the months of June and September. My goal is to convert this Vectors as points into Rhino where i can begin to draw up the lines as sunlight pathways. Is This possible ?
hi @Fin, if you right click on the center of the component and select bake, it will bring the entire sun path including the vectors on the sun path as points.
Best
Hi @Fin,
you can also take the sun_pts output and connect it to the _center_pt with a 2-point-line.
