I finished modelling my HVAC systems for my simulation using Ironbug. Everything runs, but I get a warning about my attic not having a SetPoint. This zone is not conditioned, there is no mechanical system to warm up this area. So my question is, can I just ignore this warning? or should I still add a SetPoint to it? If so, what should my SetPoint be?
@AESB99 I was going to tell you to use the HB Apply Setpoint Value component and use extreme numbers to effectively give a setpoint but have it not do anything i.e cooling setpoint 999* But when I went to test it out its giving the same error.
Hi @AbrahamYezioro, I just tried using the “HB Plenum” tool and it gives me the same error I used to have. When do you you suggest I should use this tool?
I would say that the room/zone should be assigned to the Plenum component. Set the conditioned input as False … and that’s it. In theory it should work for your case.
Check the hint of the component.
I did it but it stills give me the error. I guess, I’ll keep using the other solution. But thank you for this tip, I’ll consider it for my next simulation.
