Automatically create named Rhino views from Grasshopper
Is it possible to create a series of named views in Rhino from Grasshopper?
I am trying to automatize a DGP annual simulation from given grid points but I cannot think of a way to do this only using grasshopper. The “Daysim parameters” needs to be fed a rhino view name. It would be great if I could create and name the views automatically from grasshopper.
Hi Alejandro,
This should do it for you: http://www.grasshopper3d.com/group/ladybug/forum/topics/ladybug-vie…
PS: Why can’t you create the views beforehand and just use the names?
Looks like it is exactly what I am looking for. Thanks!
Mostapha, I amtrying your script to save the views but I cannot manage to make it work correctly. I want it to save the views as perspective and I think it is saving them as parallel views instead. Do you know a way around this? (Script attached)
Thanks in advance,
Alejandro
Script
save view.gh (12.9 KB)
Hi Alejandro,
Are you sure that the views are parallel? Works fine on my system. I guess it is an issue with setView component. Please use a slider (and not a panel) for your input for lensLength.
Mostapha
Hi Mostapha,
Thank you for all the help.
The views are parallel when I use the “Ladybug_View from sun component”, I guess it makes sense that the view from the sun is set as a parallel view, as the sun can be considered to be infinitely far away.
However, I am trying to make this work in my script using the “Ladybug_Set the view” component to set a normal view of my model. Even though I have an example file I don’t really understand how the “save views” component works and what I need to connect as imput.
Attached is my file.
save views Alejandro.gh (17.9 KB)
Hi Alejandro,
namedViewName is name of Rhino View that you want to be saved as a named view - You most likely want to leave it to Perspective.
viewName is the name of new named view.
Hope it helps,
Mostapha
