When i’m trying to bake Heatmap i have huge font. If i display result without baking the display is correct.
I can always specify the height of the text legend but it’s case specific.
Thanks in advance
Thanks in advance
Yes you are right. Thanks a lot ! I use it as a trick.
Does it look like a bug otherwise ?
Hi -
It’s a known limitation.
In Rhino 8, Grasshopper has native components to create annotations styles in the Rhino document, so, in that way, this issue has been solved.
-wim
Thanks for the clarification. Can’t wait for this update.
Have a good day
