Basic question: label the polygon name in psychrometric chart
hello,all, I want to know is there a way to label the polygon name or number in psychrometric chart in order to understand the corresponding polygon for each different strategy? Because we get so many polygons when I run it with several passive strategies and multiple clothes level, and I can not understand each of them and know the different percentage well.
Psychrometric_Chart.gh (455.1 KB)
You can use the components under Grasshopper Display tab to annotate graphics. To understand what each polygon does you can add them one by one.
Thank you for your suggestion, I will try to do it.
