Hello!
I came across a similar topic here (with no solution) but was for some reason unable to reply there so I had to start a new one.
I have downloaded and installed the Butterfly 0.0.05 and the latest BlueCFD. I run everything as an admin. The only thing I have changed was the BlueCFD path in the init.py on my D: drive befor running the Butterfly installation.
However when trying to run the example file on outdoor environment, the blockmesh component returns this readme, indicating it is looking for the controldict in the BlueCFD files:
Updating cell size in blockMeshDict.
Updating grading in blockMeshDict.
Saved changes to blockMeshDict to:
C:\Users\zdenom\butterfly\outdoor_airflow\system\blockMeshDict
Runtime error (PythonException): tee: 'log\blockMesh.log': No such file or directory
--> FOAM FATAL ERROR:
cannot find file "D:/Program Files/blueCFD-Core-2017/system/controlDict"
From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 522.
FOAM exiting
Traceback:
line 278, in _handle_process, "C:\Users\zdenom\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py"
line 213, in _run_ironpython, "C:\Users\zdenom\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py"
line 234, in run, "C:\Users\zdenom\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py"
line 756, in command, "C:\Users\zdenom\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py"
line 788, in blockMesh, "C:\Users\zdenom\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py"
line 52, in script
Could someone please give me a hint how to make it run?
