This was a bug from a recent update to ladybug-geometry library. I pushed a new fix to GitHub. If you use the update component again it should fix the problem. Here is a file with the update component to update your installation:
update_honeybee_plus.gh (5.4 KB)
After updating the installation use update_file component to update the file.
