Bug with Honeybee plus "cannot import legendparameters from ladybug"
daylight
#1
I started to use HoneybeePlus for daylight analysis and I’m facing a bug with the “annual daylight Metrics” component. It is saying that it cannot import legendparameters from Ladybug.
I did the latest update thx to “HoneybeePlus Installer” component
Does someone know why I receive that error message?
Thx in advance
#3
Hi @dvdbremt
This issue looks similar to this thread Error with HB+ GridBasedRecipe: cannot import legendparameters from ladybug
Try to delete the line no.45 to 52 from the HB+ annual metrics component.
#4
Thx,
I actually changed line 46
import ladybug.legendparameters as lp
to
import ladybug.legend as lp
since the class is called legend and not legendparameters in C:\Users\USERNAME\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\ladybug
and line 52
legend_par = lp.LegendParameters((0, 100), colors=col)
by
legend_par = lp.LegendParameters(0, 100, colors=col)
without the () since the argument needed is not a tuple…
#5
Cool, and that solved your issue?
#6
yep it s seems to be solved
#7
This was a bug from a recent update to ladybug-geometry library. I pushed a new fix to GitHub. If you use the update component again it should fix the problem. Here is a file with the update component to update your installation:
update_honeybee_plus.gh (5.4 KB)
After updating the installation use update_file component to update the file.
