Hello everyone! I am new here and I have a question regarding Butterfly tool.
It seems like everything is fine (ok, almost everything is fine
) with the algorithm. I can see the wind vectors but I do not know what is going on with the legend and the pressure data. And I do not know where a mistake is.// Does anyone knows what is going on here?
I will be very glad if someone help me.
This has been asked before. Make sure all the probes are outside the test buildings (inside the CFD mesh).
Thanks, I will check.
It seems like the problem is in the way, Butterfly considers my geometry which has angled buildings. Yeaterday I redesigned buildings: I alligned all the lines and stright angles in order to get much more accurate mesh geometry and decrease a number of mistakes, but it doesn’t help. So, I made a promitive model with one box and a cylinder in order to check the algorithm itself. And it worked with primitive objects and with the same set ups. So, how to fix the problem with existing buildings? I can not use primitives for urban analysis as it is senseless.
However, all the angled object have perfect meshing around its borders, but not stright ones…
hi
How did you solve it? I have the same problem…… :旋转的心:
