I jhave installed BlueCFD-Core 2017 and run it as admin and it works, when I use block mesh in butterfly it keeps give this error, does anyone know why?
{0;0}
- Runtime error (DecoderFallbackException): 无法将位于索引 0 处的字节 [BE] 由指定的代码页转换为 Unicode。
Traceback:
line 272, in _handle_process, “C:\Users\lin.feng3\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py”
line 211, in _run_ironpython, “C:\Users\lin.feng3\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py”
line 232, in run, “C:\Users\lin.feng3\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\runmanager_bluecfd.py”
line 756, in command, “C:\Users\lin.feng3\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py”
line 788, in blockMesh, “C:\Users\lin.feng3\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py”
line 52, in script
