Recently, I tried to test Butterfly by following the tutorials using the example file of outdoor_airflow. Unfortunately, I never got correct results as the tutorial shows. the VirtualBox and OpenFoam work fine, initially I didn’t change any components but just add toggle button to run snappyhexmesh, then I got:
the SnappyHexMesh run super slow and sometimes reports a large number of error faces(the other times 0 error, quite weird);
If connect the SnappyHexMesh component to LoadMesh component, Rhino is not responding;
the Solution component gives incorrect results, and the probes value are all zero.
Hi @Asisnath, already receive your file, thanks a lot! But I am afraid I am not able to test it right now because I met another problem recently which drives me crazy…
After I restart my laptop, the OpenFoam throws me an error as below:
I try to reinstall everything many times but the installation is always failed when waiting for an IP, and finally the error is still there. Also try several solutions online but none of them work.
I know nothing about docker so I have to give up fighting with this problem by myself…
I am wondering if you have any ideas about how to solve this problem? Thank you!
I followed the recommended steps, still failed.
It seems to only way is to format the hard drive and install everything again.
Anyway, really grateful for your help!
thank you for the detailed reply. I tried your solution this morning, still nothing changed. Actually, from my 20 times re-installation experience, the problem has something to do with the IP address in running the .exe file of “OpenCFD-OpenFOAM4WindowsInstaller_v1612+.exe”, almost everytime it will stuck in the step of “waiting for an IP” for a long time and later the error appears, no matter to run Oracle VB or docker tools or OF first. Just a guess, I know nothing about docker.
Anyway, thank you very much for your kind suggestion.
