Hello!
Today I tried to create a simple outdoor airflow analysis with Butterfly and received an error while trying to blockmesh. The error message is as follows:
SET DOCKER_TLS_VERIFY=1&SET DOCKER_HOST=tcp://192.168.99.100:2376&SET DOCKER_CERT_PATH=C:\Users\akiwya.docker\machine\machines\default&SET DOCKER_MACHINE_NAME=default&docker exec -i 4c9bb2f7444b pgrep snappyHexMesh
Butterfly is running blockMesh. PID: 1837
/---------------------------------------------------------------------------<br/> | ========= | |
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: v1612+ |
| \ / A nd | Web: www.OpenFOAM.com |
| \/ M anipulation | |
Build : v1612+
Exec : blockMesh
Date : May 22 2017
Time : 08:51:50
Host : “default”
PID : 1837
Case : /home/ofuser/workingDir/butterfly/outdoor_airflow
nProcs : 1
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
“/home/ofuser/workingDir/butterfly/outdoor_airflow/system/blockMeshDict”
Creating block edges
No non-planar block faces defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 6
Number of defined boundary faces : 6
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Runtime error (PythonException):
Butterfly failed to run OpenFOAM command!
Traceback:
line 51, in script
I don’t really have any knowledge in CFD simulation and only watched the tutorials and managed to get the sample files to work. So this time, I replaced the starting geometry my building which is a curve building, I wonder if that is the issue that caused this problem. Can anyone enlighten me on the issue?
Warm regards,
Annie
Building Creation_WIND.gh (461 KB)
