Hi Ladybug community, I am new to ladybug and just installed butterfly. When I try to run the example file as a test, an error occurred.
{0;0}
- Updating cell size in blockMeshDict.
- Updating grading in blockMeshDict.
- Saved changes to blockMeshDict to:
C:\Users\50532\butterfly\outdoor_airflow\system\blockMeshDict - Runtime error (PythonException): ‘“C:\Program Files\blueCFD-Core-2020\setvars.bat”’ ²»ÊÇÄÚ²¿»òÍⲿÃüÁҲ²»ÊÇ¿ÉÔËÐеijÌÐò
»òÅú´¦ÀíÎļþ¡£
‘blockMesh’ ²»ÊÇÄÚ²¿»òÍⲿÃüÁҲ²»ÊÇ¿ÉÔËÐеijÌÐò
»òÅú´¦ÀíÎļþ¡£
Traceback:
line 278, in _handle_process, “C:\Users\50532\AppData\Roaming\McNeel\Rhinoceros\7.0\scripts\butterfly\runmanager_bluecfd.py”
line 213, in _run_ironpython, “C:\Users\50532\AppData\Roaming\McNeel\Rhinoceros\7.0\scripts\butterfly\runmanager_bluecfd.py”
line 234, in run, “C:\Users\50532\AppData\Roaming\McNeel\Rhinoceros\7.0\scripts\butterfly\runmanager_bluecfd.py”
line 756, in command, “C:\Users\50532\AppData\Roaming\McNeel\Rhinoceros\7.0\scripts\butterfly\case.py”
line 788, in blockMesh, “C:\Users\50532\AppData\Roaming\McNeel\Rhinoceros\7.0\scripts\butterfly\case.py”
line 52, in script
How can I fix it? I don’t know coding at all.
Thanks in advance
