While I was trying to run the Outdoor Airflow Modeling from examples with Butterfly, I realized that something is wrong with Oracle VM / Openfoam and I cannot find what.
First, this error comes up when I try to run Docker VM :
“NtCreateFile(\Device\VBoxDrvStuv) failed:0xc0000034
STATUS_OBJECT_NAME_NOT_FOUND (0 retries) (rc=-101)
Make sure the kernel module has been loaded successfully.
where: supR3HardenedWinReSpawn what :3 VERR_OPEN_FAILED (-101) - File/Device open failed. Driver is propably stuck stopping/starting. Try ‘sc.exe query vboxdrv’ to get more information about its state. Rebooting may actually help.”
I did try to reboot but it didn’t work. I also tried to uninstall and reinstall OpenFoam and Oracle VM without success.
Also when I try to run the blockmesh in the grasshopper’s script, I get that message :
"Solution exception:Error checking TLS connection: Host is not running
Docker machine is not running! Run Oracle VM VirtualBox Manager as administrator and make sure “default” machine is “running”.
I did run Oracle VM, Openfoam and Rhino as administrator, so I don’t see from where comes the issue.
I eventually gave up and cannot really help you Gunsu. The close deadline forced us to switch to a mix of another software & spreadsheets for the simulation.
Sorry for the late answer.
For the future reference we moved on from OpenFOAM for Windows to blueCFD which is a port of OpenFOAM that works natively on Windows. No need to VM and Docker anymore and hence fewer installation issues.
