Butterfly installation problems——solution exception:failed to import butterfly:set your installation flavor in confing.yml
hi, Mr.butterfly, when I finished installed butterfly in rhino 6 and let butterfly fly, I got this error.
I checked code of this block, it seemed that butterfly can only install in rhino 5.0. And I adjust the path from 5.0 to 6.0, it doesn’t work.
So how to solve it, I have been puzzled for many days.
I’ve just installed Butterfly and it said that it has been successful, but I’m getting the same error as described above.
you can uninstall blueCFD and install it in the default installation path
Can you write the deatails about the default installation path? Thank you very much!!!
Hi,@ForeverJack The default path of blueCFD-core is C:\Program Files\blueCFD-Core-2017.Please check it.
OK,I will try. Can I know which system version of your computer?Win7、Win8 or Win10?
@ForeverJack My system is Win 10
I think I miss a very important part. You install Rhino6.0 in your computer or Rhino5.0? I am not sure if there is a matching problem between the both versions of Rhino and your system.
Hi,@ForeverJack I am using Rhino 6 SR11 64bit\Butterfly 0.0.05\BlueCFD core 2017.2. These software worked fine on Windows 10 64bit system
Thank you very much! It works.
Hi @minggangyin - is there a specific reason for still using SR11?
-wim
Hi,@wim Rhino 6 SR11 or newer worked fine
I got the same problem as title.
My info: Win10 64 ; Rhino 6 SR23; Butterfly 0.0.05
What can i do?
Hi,@wanaboy Butterfly worked fine on my work station and my laptop.
Problem solved.
Set your openfoam installation path exactly to: ‘‘C:\Program Files\blueCFD-Core-2017’’.
I’m using win10 x64 & Rhino 6 SR23 & openfoam-v1912 (https://www.openfoam.com/releases/openfoam-v1912/).
Butterfly battery alive~
Thanks to Nan1939 and minggangyin
Do you think it will it work on Rhino5?
Hi
BlueCFD Team Release now version of their work. and supports the new OpenFoam_V8.Does Butterfly support it?
Thanks in Advance
I have exactly that, but I’m getting
“Failed to import butterfly:
No module named butterfly.boundarycondition”
:point_right:t3: Rhino 7 on Win10, BF 0.0.05, blueCFD-Core-2017
Any hints/help/tipps to get it running are appreciated!
Not sure I can Install Rhino 6 with my 7&8 Lics…
What a shame that Butterfly isn’t maintained, this could be such a great tool!
Ah, so apparently the Installer only installs the connection to OF??
Now I also placed the Butterfly-files into the common plugin-folder and the error goes away…
On to the next challenge with this… :slight_smile:
