I’ve set up wind velocity and wind pressure model by butterfly components, but unfortunately, I cannot get correct results.
in wind velocity analysis all arrows are the same color, and in wind pressure analysis all the grids are in a same color too!
How can I solve this problem?
Also the legend is disappeared!
Hi @niloofarzaker You should upload some screeshot of your model and grasshopper definition for further discussion.
@niloofarzaker The meshing of your model is too coarse and the result is not smooth for visualization.
I modify your settings and got a better result.
Here is the modified version .
Wind-NW-Algorithm—3-fixed.gh (1.4 MB)
Thanks alot for yout time.
