I tried my best to install, and run open foam and butterfly. And by searching many answers on GitHub, I solved a lot of problems in this process. But I still got a final problem before I get the analysis result. Hope someone can help me out. (I really struggled for itđ)
I used the file uploaded by devang. I use the latest butterfly version 0.0.05.
The screen shot below shows where the problem is. The vectors to come out as (0,0,0) in solution component. no visualization appear of the airflow.
It seems like no vectors are generated. Therefore also no wind visualization occur. Ux, Uv and Uz remains 0 during the loop in OpenFoam. But all the components run in Open Foam without any errors. (Iâve updated all the components to the latest version and match the rhino unit with meter but still donât work) the same question as the one who got previously but no answer yet.
The result of solution component didnât have âsimplefoamâ folder(and My computer folder didnât have it either as shown in the picture), so the plot residuals cannot run. However, the panel connected solution component said it create simple foam folder.
Solution exception:Failed to parse C:\Users\CatherineD\butterfly\Outdoor_Sample\log\simpleFoam.log:
[Errno 2] Could not find file âC:\Users\CatherineD\butterfly\Outdoor_Sample\log\simpleFoam.logâ.: C:\Users\CatherineD\butterfly\Outdoor_Sample\log\simpleFoam.log
Thank you for your attention! Does ârun case firstâ mean run âcreate BFgeometryâ first? I did run it first, then âblockmeshâ, âsnappyhexmeshâ ,âgenerate testpointâ and finally âsolutionâ. But it didnât work.
I am facing same kind issues, very simple example mass blocks works.
these are errors appears, I try to reduce mesh count and grid options, I get the same errors.
