Dear butterfly experts,
I have a flaoting issue when running buoyantBoussinesqSimpleFoam (prototype hvac.gh) through grasshopper. Can anyone help tell how can I solve it?
Many thanks.
Mark
/---------------------------------------------------------------------------<br/>| ========= | |
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: v1612+ |
| \ / A nd | Web: www.OpenFOAM.com |
| \/ M anipulation | |
Build : v1612+
Exec : buoyantBoussinesqSimpleFoam -parallel
Date : May 22 2017
Time : 10:18:58
Host : "default"
PID : 2839
Case : /home/ofuser/workingDir/butterfly/simple_hvac
nProcs : 4
Slaves :
3
"default.2840"
"default.2841"
“default.2842”
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field nut tolerance 0.0001
field p_rgh tolerance 0.0001
field k tolerance 0.0001
field U tolerance 0.0001
field T tolerance 0.0001
field epsilon tolerance 0.0001
field alphat tolerance 0.0001
Reading thermophysical properties
Reading field T
Reading field p_rgh
Reading field U
Reading/calculating face flux field phi
Selecting incompressible transport model Newtonian
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model RNGkEpsilon
RNGkEpsilonCoeffs
Cmu 0.0845;
C1 1.42;
C2 1.68;
C3 -0.33;
sigmak 0.71942;
sigmaEps 0.71942;
eta0 4.38;
beta 0.012;
Reading field alphat
Reading g
Reading hRef
Calculating field g.h
No MRF models present
Radiation model not active: radiationProperties not found
Selecting radiationModel none
No finite volume options present
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.06427477, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.06226344, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.03950103, No Iterations 3
smoothSolver: Solving for T, Initial residual = 1, Final residual = 0.03671111, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.008356878, No Iterations 86
DICPCG: Solving for p_rgh, Initial residual = 0.07888434, Final residual = 0.0006831407, No Iterations 9
DICPCG: Solving for p_rgh, Initial residual = 0.007053905, Final residual = 6.211827e-05, No Iterations 71
time step continuity errors : sum local = 3777.266, global = 3.22967, cumulative = 3.22967
smoothSolver: Solving for epsilon, Initial residual = 0.9994728, Final residual = 0.0532353, No Iterations 4
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.05640973, No Iterations 4
ExecutionTime = 2.65 s ClockTime = 3 s
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.5142984, Final residual = 0.02186577, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.5242573, Final residual = 0.02244622, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.5106874, Final residual = 0.02933279, No Iterations 2
smoothSolver: Solving for T, Initial residual = 0.3832824, Final residual = 0.01046751, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.9825413, Final residual = 0.009757923, No Iterations 799
DICPCG: Solving for p_rgh, Initial residual = 0.04390194, Final residual = 0.000303611, No Iterations 9
DICPCG: Solving for p_rgh, Initial residual = 0.0073043, Final residual = 7.259574e-05, No Iterations 45
time step continuity errors : sum local = 1883567, global = 2227.205, cumulative = 2230.435
smoothSolver: Solving for epsilon, Initial residual = 0.08647006, Final residual = 0.000113174, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.1579946, Final residual = 0.01115579, No Iterations 2
ExecutionTime = 9.56 s ClockTime = 10 s
Time = 3
smoothSolver: Solving for Ux, Initial residual = 0.8070853, Final residual = 0.07865708, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.8145663, Final residual = 0.03882168, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.5761609, Final residual = 0.0390739, No Iterations 4
smoothSolver: Solving for T, Initial residual = 0.1644957, Final residual = 0.006771158, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.7802636, Final residual = 0.006709539, No Iterations 13
DICPCG: Solving for p_rgh, Initial residual = 0.04575494, Final residual = 0.0004415382, No Iterations 130
DICPCG: Solving for p_rgh, Initial residual = 0.005830491, Final residual = 5.648426e-05, No Iterations 78
time step continuity errors : sum local = 6.68889e+12, global = -4.053656e+11, cumulative = -4.053656e+11
smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.08337707, No Iterations 1
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.08762031, No Iterations 2
ExecutionTime = 11.24 s ClockTime = 11 s
Time = 4
smoothSolver: Solving for Ux, Initial residual = 0.1870785, Final residual = 0.008250987, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.1039591, Final residual = 0.003633928, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.003344756, Final residual = 0.0001428352, No Iterations 2
smoothSolver: Solving for T, Initial residual = 0.0360337, Final residual = 0.0008781286, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.9999995, Final residual = 0.7505781, No Iterations 1001
DICPCG: Solving for p_rgh, Initial residual = 2.097918e-11, Final residual = 2.097918e-11, No Iterations 0
time step continuity errors : sum local = 9.100777e+16, global = -1.152626e+15, cumulative = -1.153031e+15
smoothSolver: Solving for epsilon, Initial residual = 0.006323925, Final residual = 0.0002800085, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.9999998, Final residual = 0.08579136, No Iterations 4
ExecutionTime = 15.48 s ClockTime = 16 s
Time = 5
smoothSolver: Solving for Ux, Initial residual = 0.6268107, Final residual = 0.01889084, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.5691313, Final residual = 0.02593386, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.525286, Final residual = 0.01999095, No Iterations 2
smoothSolver: Solving for T, Initial residual = 0.1776883, Final residual = 0.004896742, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.8409992, Final residual = 0.008296552, No Iterations 25
DICPCG: Solving for p_rgh, Initial residual = 8.57445e-13, Final residual = 8.57445e-13, No Iterations 0
time step continuity errors : sum local = 3.230307e+23, global = -5.044393e+14, cumulative = -1.657471e+15
smoothSolver: Solving for epsilon, Initial residual = 4.732135e-05, Final residual = 1.311093e-10, No Iterations 1
bounding epsilon, min: -1.103807e+26 max: 1.972571e+51 average: 2.670218e+47
smoothSolver: Solving for k, Initial residual = 0.04771126, Final residual = 0.002285774, No Iterations 2
ExecutionTime = 16.44 s ClockTime = 17 s
Time = 6
smoothSolver: Solving for Ux, Initial residual = 0.9995642, Final residual = 0.04432588, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.9996968, Final residual = 0.04761556, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.9858131, Final residual = 0.06924769, No Iterations 3
smoothSolver: Solving for T, Initial residual = 0.01200576, Final residual = 0.0002952721, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.9446084, Final residual = 0.005339222, No Iterations 6
DICPCG: Solving for p_rgh, Initial residual = 0.08971123, Final residual = 0.0008218812, No Iterations 6
DICPCG: Solving for p_rgh, Initial residual = 0.02323654, Final residual = 0.0002319251, No Iterations 193
time step continuity errors : sum local = 4.926861e+44, global = -1.110593e+37, cumulative = -1.110593e+37
smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.002671469, No Iterations 2
bounding epsilon, min: -2.219668e+47 max: 1.75779e+78 average: 3.182358e+73
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0501481, No Iterations 2
bounding k, min: -3.660183e+25 max: 9.966186e+62 average: 8.53815e+58
ExecutionTime = 18.1 s ClockTime = 18 s
Time = 7
smoothSolver: Solving for Ux, Initial residual = 8.069155e-09, Final residual = 8.069155e-09, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 5.382338e-08, Final residual = 7.473481e-09, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 2.092083e-08, Final residual = 2.077615e-09, No Iterations 1
smoothSolver: Solving for T, Initial residual = 0.1619372, Final residual = 0.003564584, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 46631.37, No Iterations 1001
DICPCG: Solving for p_rgh, Initial residual = 1.64537e-26, Final residual = 1.64537e-26, No Iterations 0
time step continuity errors : sum local = 1.468529e+53, global = 5.868436e+40, cumulative = 5.867326e+40
smoothSolver: Solving for epsilon, Initial residual = 0.07343377, Final residual = 2.828068e-19, No Iterations 1
bounding epsilon, min: -2.257804e+66 max: 8.093947e+109 average: 1.184346e+105
smoothSolver: Solving for k, Initial residual = 0.5212037, Final residual = 0.02939162, No Iterations 2
ExecutionTime = 22.26 s ClockTime = 22 s
Time = 8
smoothSolver: Solving for Ux, Initial residual = 0.6924604, Final residual = 0.01784756, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.3637153, Final residual = 0.005737122, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.2793264, Final residual = 0.00626238, No Iterations 2
smoothSolver: Solving for T, Initial residual = 0.07790577, Final residual = 0.002676894, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.8911507, Final residual = 0.008688155, No Iterations 18
DICPCG: Solving for p_rgh, Initial residual = 1.957294e-52, Final residual = 1.957294e-52, No Iterations 0
time step continuity errors : sum local = 8.548233e+90, global = -3.056251e+75, cumulative = -3.056251e+75
mpirun noticed that process rank 1 with PID 2840 on node default exited on signal 8 (Floating point exception).
[1] #0 Foam::error:
rintStack(Foam::Ostream&)[0] #0 Foam::error:
rintStack(Foam::Ostream&) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so”
[0] #1 Foam::sigFpe::sigHandler(int) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so”
[1] #1 Foam::sigFpe::sigHandler(int) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so”
[0] #2 ? in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so”
[1] #2 ? in “/lib64/libc.so.6”
[0] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in “/lib64/libc.so.6”
[1] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so”
[0] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:
perator<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so”
[1] #4 void Foam::multiply<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so”
[1] #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:
perator*<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so”
[1] #6 Foam::RASModels::RNGkEpsilon<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::correct() in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so”
[1] #7 ? in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqSimpleFoam”
[1] #8 __libc_start_main in “/lib64/libc.so.6”
[1] #9 ? in “/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqSimpleFoam”
[default:02840] *** Process received signal ***
[default:02840] Signal: Floating point exception (8)
[default:02840] Signal code: (-6)
[default:02840] Failing at address: 0x1f400000b18
[default:02840] [ 0] /lib64/libc.so.6(+0x32660)[0x7f516d4f4660]
[default:02840] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x7f516d4f45e5]
[default:02840] [ 2] /lib64/libc.so.6(+0x32660)[0x7f516d4f4660]
[default:02840] [ 3] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(ZN4Foam8multiplyERNS_5FieldIdEERKN S_5UListIdEES6+0xd5)[0x7f516e7bfd55]
[default:02840] [ 4] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(ZN4Foam8mult iplyINS_12fvPatchFieldENS_7volMeshEEEvRNS_14Geomet ricFieldIdT_T0_EERKS6_S9+0x41)[0x7f5172705861]
[default:02840] [ 5] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4FoammlINS 12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14Geometr icFieldIdT_T0_EEEERKS7_RKS8+0x15b)[0x7f5172784afb]
[default:02840] [ 6] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam9RASM odels11RNGkEpsilonINS_29IncompressibleTurbulenceMo delINS_14transportModelEEEE7correctEv+0x2d0)[0x7f51727d5ec0]
[default:02840] [ 7] buoyantBoussinesqSimpleFoam[0x481a7d]
[default:02840] [ 8] /lib64/libc.so.6(__libc_start_main+0xfd)[0x7f516d4e0d1d]
[default:02840] [ 9] buoyantBoussinesqSimpleFoam[0x42db51]
[default:02840] *** End of error message ***
Hi Mark, If all the settings are set as default can you make sure that your Rhino units are in Meters? The room is sized based on meters.
Dear Mostapha,
Thanks for the reminder
dear Mostapha,
i have a similar problem in running it. But I use the blueCFD to set the openFoam x5. I’m not sure whether it right, since it run super slow. I just run the outldoors-airflow gh file in example file, and just imput the default setting.And it’s still running in my laptop,so I have no ending in here.
ps: do I need enable the virtualization Technology in BIOS? the result also super slow.
Do you have any ideas? thanks!
Hazel
c:\Users\pinenut\butterfly\outdoor_airflow>call “C:\Program Files\blueCFD-Core-2017\setvars.bat”
| \ / O peration | Version: 5.x |
| \ / A nd | Web: www.OpenFOAM.org |
/ Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt
| Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
Build : 5.x-963176928289
Exec : simpleFoam
Date : Mar 17 2019
Time : 15:46:01
Host : “DESKTOP-B6V89AF”
PID : 4208
I/O : uncollated
Case : c:/Users/pinenut/butterfly/outdoor_airflow
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
field p tolerance 0.0001
Reading field p
Reading field U
RAS
RASModel RNGkEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.0845;
C1 1.42;
C2 1.68;
C3 0;
sigmak 0.71942;
sigmaEps 0.71942;
eta0 4.38;
beta 0.012;
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.077693552, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for p, Initial residual = 1, Final residual = 0.08745413, No Iterations 14
GAMG: Solving for p, Initial residual = 0.0025207207, Final residual = 0.00017747632, No Iterations 10
GAMG: Solving for p, Initial residual = 0.00029629035, Final residual = 2.6687491e-005, No Iterations 12
time step continuity errors : sum local = 6.0274538e-005, global = -2.0995308e-005, cumulative = -2.0995308e-005
smoothSolver: Solving for epsilon, Initial residual = 0.028800124, Final residual = 0.0023425014, No Iterations 3
smoothSolver: Solving for k, Initial residual = 0.99999991, Final residual = 0.085374649, No Iterations 3
ExecutionTime = 203.321 s ClockTime = 203 s
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.50449235, Final residual = 0.0249933, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.49215059, Final residual = 0.046051627, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.50992584, Final residual = 0.025890667, No Iterations 4
GAMG: Solving for p, Initial residual = 0.088212523, Final residual = 0.0058148908, No Iterations 10
GAMG: Solving for p, Initial residual = 0.0032440853, Final residual = 0.00028235468, No Iterations 8
GAMG: Solving for p, Initial residual = 0.00039722141, Final residual = 3.8092695e-005, No Iterations 13
time step continuity errors : sum local = 3.8145144e-005, global = 2.6856998e-005, cumulative = 5.8616904e-006
smoothSolver: Solving for epsilon, Initial residual = 0.00092940406, Final residual = 4.7187641e-005, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.6645933, Final residual = 0.036315279, No Iterations 4
ExecutionTime = 288.57 s ClockTime = 288 s
Time = 3
smoothSolver: Solving for Ux, Initial residual = 0.22630106, Final residual = 0.012106535, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.31994527, Final residual = 0.029790728, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.24944196, Final residual = 0.013720395, No Iterations 4
GAMG: Solving for p, Initial residual = 0.064665212, Final residual = 0.0039610522, No Iterations 14
GAMG: Solving for p, Initial residual = 0.0057392921, Final residual = 0.00041438138, No Iterations 10
GAMG: Solving for p, Initial residual = 0.0007168088, Final residual = 6.7704278e-005, No Iterations 17
time step continuity errors : sum local = 5.238233e-005, global = -3.4164441e-005, cumulative = -2.8302751e-005
smoothSolver: Solving for epsilon, Initial residual = 0.0028437639, Final residual = 0.00014840951, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.33626168, Final residual = 0.019038974, No Iterations 4
ExecutionTime = 383.722 s ClockTime = 384 s
Time = 4
smoothSolver: Solving for Ux, Initial residual = 0.1230413, Final residual = 0.011569523, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.076346218, Final residual = 0.0074804446, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.098999423, Final residual = 0.0098715769, No Iterations 3
GAMG: Solving for p, Initial residual = 0.13820949, Final residual = 0.0094114892, No Iterations 14
GAMG: Solving for p, Initial residual = 0.0029967583, Final residual = 0.00022038271, No Iterations 10
GAMG: Solving for p, Initial residual = 0.00039448982, Final residual = 3.9238432e-005, No Iterations 17
time step continuity errors : sum local = 5.1633048e-005, global = -3.3317156e-005, cumulative = -6.1619907e-005
smoothSolver: Solving for epsilon, Initial residual = 0.0048102738, Final residual = 0.00025077582, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.17781074, Final residual = 0.0099807833, No Iterations 4
ExecutionTime = 472.486 s ClockTime = 472 s
Time = 5
smoothSolver: Solving for Ux, Initial residual = 0.24973826, Final residual = 0.022011009, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.13386363, Final residual = 0.011628322, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.2652395, Final residual = 0.025390489, No Iterations 3
GAMG: Solving for p, Initial residual = 0.11533987, Final residual = 0.006310438, No Iterations 8
GAMG: Solving for p, Initial residual = 0.0044259232, Final residual = 0.00030765634, No Iterations 8
GAMG: Solving for p, Initial residual = 0.00050012341, Final residual = 4.749114e-005, No Iterations 10
time step continuity errors : sum local = 2.4800394e-005, global = 4.1566202e-006, cumulative = -5.7463286e-005
smoothSolver: Solving for epsilon, Initial residual = 0.0031114663, Final residual = 0.00029587057, No Iterations 3
smoothSolver: Solving for k, Initial residual = 0.074840439, Final residual = 0.0073588472, No Iterations 3
ExecutionTime = 547.295 s ClockTime = 547 s
