Hi everyone- I am new to Butterfly. I’ve tried to run some of the scripts from Hydra but haven’t been successful. So I’m hoping when this error from the Sample Case script is resolved, it might solve other problems…
I’m getting an assertion error on the component Butterfly_SampleCase. See screenshot below and the error from OpenFOAM is pasted underneath.
| \\ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \\ / O peration | Version: 5.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
/* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\
| Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
Build : 5.x-963176928289
Exec : postProcess
Date : Aug 03 2020
Time : 15:07:01
Host : *///////companyhostcomputer////////*
PID : 47176
I/O : uncollated
Case : c:/Users/schoi/butterfly/outdoor_airflow
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0
Reading fields:
Executing functionObjects
Time = 1
Runtime error (AssertionException): AssertionError
Traceback:
line 832, in sample, "C:\Users\schoi\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py"
line 57, in script
More info:
- I am running Rhino 6 in Administrator mode.
- I’m running Butterfly ver 0.0.05. I’ve updated all of the components on the Hydra script (from ver 0.0.04)
- I have Blue CFD installed (Core-2017)
- All plugins were added to my computer May 2020
Let me know if I need to provide more info.
Thanks!
Sue
