I have a problem where the ‘generate test points’ component creates points that are inside the refined Snappyhexmesh of the object. This creates some results that have super high pressures which need to be filtered out in order to get the coloured vector display in the example file. the problem seems to come up in two ways
1 . the meshing of the test geometry is too coarse, and triangles are formed where the centre point is actually inside the object - see third image. I think this can be resolved by just increasing the density of the test mesh so it’s about equal to the snappyhexmesh at the surface. Is this right?
- For the test object plane that is cutting obliquely through the object, the points actually move off the plane toward the mesh. This seems to happen regardless of whether ‘move test mesh’ is true or false. When I move the plane to where the points are, they move again next time the solution is run. As you can see in my example, if these points move toward the centre of the sphere, then they are inside the object and skew the result.
What am I doing wrong here? Guessing this question has been answered somewhere before but I couldn’t find anything specifically answering this question so far.
thanks
Nick
200531_Sphere.gh (441.1 KB)
