Running Vs 5 for the first time. Unloaded my old Openfoam and installed the new one. The swoosh worked fine with no errors but when I run any of your examples and run this one component it gives me an error related to “handles”. Can you help me to address the cause of this problem. See snippet.
thanks Ken
hi,@kennethwmartin
Are you using BlueCFD for simulation?
Hi @kennethwmartin,
Can you share a screenshot of the full report. The error seems to have with w
versus wb
handler for opening new files to write the files but I’m not sure why is it happening. report
output should give us the full trace of the error. Thanks.
