You have a non-ascii character in your computer username and, unfortunately, the simulation engines used by LBT won’t play nicely with these characters. The easiest way around this is to create a new username on your computer that has only ASCII characters. Then, you should be able to run the installer and Ladybug Tools when you are signed into that username.
