In the settlement I am trying to create, I use the Dragonfly plugin instead of Honeybee because the building I am working on consists of too much volume. However, I couldn’t figure out how to connect the schedules I created here to the dragonfly plugin. Is there a way to this? I have shared the relevant sections in the .gh file below. I will be grateful if you could help me
You were very close. You just need to make sure that you are generating only one Program object and then you can assign this to your Dragonfly Geometry like so:
Also, I recommend that you carefully read the description of the HB Seasonal Schedule component since you were not using it correctly in your file. The component is set up so that you have one base schedule and then you connect aligned lists of other schedules and analysis periods for the parts of the year where the base schedule is to be overridden.
