Dear all,
Will there be a batch file created when Ladybug 1.5 is used? If not, is there any way we could see what Radiance Command lines are being proceeded? Many thanks!
Sichen
Dear all,
Sichen
Hi @SichenLu,
There is not single batch file like previous versions. It’s a bit more complicated.
You can add a debug_folder to the recipes in Grasshopper.
You will then have a folder where each task of the recipe is its folder.
In each folder there is a command.bat file.
You can add --dry-run to the command and execute the file. The --dry-run will not execute the command but just show the Radiance command. Some commands in the command.bat files will not have a --dry-run option. This is because they are not executing a Radiance command, e.g., post-processing annual metrics.
Hi Mikkel,
Thank you so much!
Sichen
Hi Mostapha,
That’s very cool! It helps us to visualize the whole process.
Sichen
