lkvsa
July 15, 2021, 1:46pm
1
I wonder if it was possible to launch an analysis with radiance on the analysis of the reflections, a topic has already been opened on this subject.
Hi, everyone,
I am trying to analyze a concave facade to see if there’s too much reflection on one spot. When I was doing research I found one paper mentioned there’s some radiance simulation method to run rtrace for forward ray racing and Rtcontrib to quantify the reflected daylight. Since ladybug and honeybee are open source I feel like I can modify the code to run those analysis but couldn’t locate the exact line of code to do the modification. Anyone can help?
I have got the target area th…
I would like to do an analysis with single, double, triple, quadruple superpositions of reflections and output a false color image.
lkvsa
July 19, 2021, 1:29pm
2
Well… i’ve tried the mostapha solution, but “pcomb” doesn’t work on my desktop, it just loopback and tried to create the difference between my two images…
https://1drv.ms/u/s!AicSPYM8QWjka-FCcMoc3hc6YcM?e=Db5Q3l
EDIT: I did it ! just a little problem of syntax in my py code ^^
