Hi
I am having problem with honeybee installation.Does anyone know how to solve this problem?
@bhattkhushbu If you are first time to run honeybee, you should use the default folder as ladybug compotent showed.
Thank you for your response @minggangyin. First I tried without creating any input path also, but it was showing same error.
What’s the message when you remove your input from the default folder?
It got resolved. Thank you for your response.
Hello Bhattkushbu,
I also have the same issue with you.
Could you please tell me how did you fix it?
