I am trying to run energy simulation using exportToOpenStudio component applying measure with
Load OpenStudio Measure. However, I get following error from exportToOpenStudio component because batch file generated and executed fail to run and cannot produce the result files in run folder.
- Solution exception:Could not find a part of the path ‘D:\Kat\Model_Case1\OpenStudio\run\pre-preprocess.idf’.
However, when I run the batch file directly as shown below, it can run simulation correctly.
Does anyone know why this happens and how to solve?
