Hi everyone,
I’m attempting to specify individual simulation outputs for the runEnergySimulation component. The description states that in order to produce the list of outputs I want EnergyPlus to write into, I must use the “Honeybee_Write EP Result Parameters Component”. However, from what I can tell, such a component no longer exists (if it ever did).
What should I do? I need to specify additional outputs so that I can use them for comfort analysis later.
Thanks. See attached a picture describing my situation.
