Can't find the default occupancy file error
hello Guys
the (( Read Annual Daylight Results I)) component shows this message error " 1. Can’t find the default occupancy file at: c:\ladybug\DaysimCSVOCC\userDefinedOcc_9to17.csv
You can generate an occupancy file and connect the file address to occupancyFiles_ input."
I searched on the net to find out the reason but I got nothing.
please help
I upload file in :
Please try updating the components and recompute the graph. The file should be automatically created.
I am encountering the same error. I tried updating the components (Feb 2020) and recomputing the canvas too. See screen shot below. Can someone post the .csv file so I can download and manually past into the c\ladybug folder? Thanks.
@devang @chris
hi again
i think it is a universal problem
Hi
I also found this problem in the new version of Windows.
What is the solution to this problem?
I manually past that file into the c\ladybug folder. Is this wrong?
@Mohammad.hakim.a so what should we do now ?
I don’t know but i manually passed that file into the C:\ladybug\DaysimCSVOCC folder then it is fixed.
I attached that file.
userDefinedOcc_9to17.csv (107.5 KB)
