Hi everyone,
I have generated some HDR images through the components ‘image-based analysis’ and ‘run daylight analysis’ (versions 0.0.66) with the following parameters:
My problem is that I cannot load the HDR images I get from the analysis into Matlab with the function ‘hdrread’ and it doesn’t work in Python either. When I use hdr images found on the web I can load them, and I fear that it is because there is something wrong with my images?
Example of all hdr images generated in one simulation ( I can’t attach my zip file, so I’ve attached the folder with my HDR images via the link below):
