Hey,
the component “Set EP Air Flow” is giving me this:
The Window dimensions are very wrong (1380 m?). Maybe it’s because I created the model in millimeters?
Thanks!
Hey,
Thanks!
For energy simulations the model MUST be in meters.
Thank you very much for your answer!
@AbrahamYezioro 's comment is historically correct and we still recommend that everyone use meters by default since E+ runs in meters and building Rhino models in meters makes everything run much faster by saving Honeybee from the need to do extra scaling operations.
However, for a little over a year now, we have supported the use of all major units systems (ft, in, mm, cm) for those times when people face a lot of struggles working in meters (*cough U.S. offices *cough). So what you have found here @adriancasadecampo is technically a bug. It seems that we forgot to update this property when we made the transition to supporting more units system.
Thanks for finding it and I just pushed a fix to the github:
