Changing the display from radiance (kWh/m2) to luminance (cd/m2) on sky dome
Dear All,
I am trying to get the value of each patch of CIE Standard Skies. I found a web application that Andrew Marsh made. (PD: CIE Sky Model) It allows me to choose to display sky radiance (W/m2) or sky luminance (cd/m2).
It is a convenient tool, but I want to get all the values of the patches as a list, and not just click each patch one by one and then record them, so I tried to use the component “LB Sky Dome”. The unit of the results are kWh/m2, but I want to change them into cd/m2. Is it possible to achieve this?
Your support is highly appreciated.
Thank you,
Alex
Hi @Alex_Huang ,
We haven’t yet added support for rending skies in the LBT plugin but you can use the Legacy “Honeybee_Watch the Sky” component to visualize illuminance-based skies like you can see discussed here:
