I’m running into a reproducible bug with Ironbug’s ChilledWaterLoop/CWLoop component and wanted to check whether this is known, and whether there’s a canvas-side fix I’m missing.
Setup:
- Ironbug 1.21.0.0 on Rhino/Grasshopper, EnergyPlus 25.1.0
ChilledWaterLoop(CWLoop) component, wired with:- Supply:
PlantComponent:TemperatureSource(constant 13°C, standing in for a black-box ground source) + a pump, on the supply branch - Demand: three
Coil:Cooling:Waterbranches in parallel
- Supply:
The bug:
** Severe ** Invalid [pump] component found on equipment list.
Pumps are not allowed on equipment lists.
Problem component name = PUMP CONSTANT SPEED 1
** Fatal ** InitLoadDistribution: Fatal error caused by previous severe error(s).
What I’ve tried (all reproduce the identical error):
- Switching the pump between
Pump:ConstantSpeedandPump:VariableSpeed— same fatal error either way, just with the corresponding pump type named in the equipment list. - Changing the canvas wiring topology — merging the pump and equipment into one wire vs. feeding them into
supplyas separate/parallel connections (matching the pattern used in Ironbug’s own bundled “Chilled water loop” example file) — no change in behavior. - Switching from
ChilledWaterLoop/CWLoopto the genericPlantLoopcomponent then the pump error disappear but i get:
** Severe ** [PlantEquipmentOperation:CoolingLoad][Plant Equipment Operation Cooling Load 1] - Missing required property ‘load_range_1_lower_limit’.
** Severe ** [PlantEquipmentOperation:CoolingLoad][Plant Equipment Operation Cooling Load 1] - Missing required property ‘load_range_1_upper_limit’.
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
…Summary of Errors that led to program termination:
… Reference severe error count=2
… Last severe error=[PlantEquipmentOperation:CoolingLoad][Plant Equipment Operation Cooling Load 1] - Missing required property ‘load_range_1_upper_limit’.
Question for the community: is this a known issue? How could i solve it?
Flirsch_v11_HVAC_variants_withcoolingcoil.gh (1.0 MB)
Thanks!
