Hallo dear @chris,
I’m sorry if I disturb you, but I kindly need one information, that I can’t extrapolate.
I would need to document and also find out wich “Overcast sky” is used in the Daylight Factor recipe in the new LBT.
Is used the formula of the CIE Standard Overcast Sky (Type 1) or the Traditional CIE Overcast Sky (Type 16)?
Into the Radiance Gensky Sky https://www.radiance-online.org//learning/documentation/manual-pages/pdfs/gensky.pdf, the Cloudy sky correspond to the standard CIE overcast day.
Is the same used for the HB_DaylightFactor component(LBT 1.1.0) or is different (for example) from the cloudy sky that I can find in the CIESky component?
Thanks in advance
Here is the command that we use to generate the sky for Daylight factor simulation:
It translates to !gensky -ang 45 0 -c -B 558.659218 -g 0.200
. Here is the sky definition:
skyfunc glow sky_glow
0
0
4 1.000 1.000 1.000 0
sky_glow source sky
0
0
4 0 0 1 180
skyfunc glow ground_glow
0
0
ground_glow source ground
0
0
4 0 0 -1 180
−c Cloudy sky. The sky distribution will correspond to a standard CIE overcast day.
