Hi Maha,
I don’t really know the abbreviations. You should send this question to Radiance mailing list. All honeybee does is calling Radiance gensky or gendaylit to generate the sky.
Here is the exact formula is inside /lib/skybright.cal if this can help you to find the name.
{ RCSid: $Id$ }
Sky brightness function for sunny and cloudy skies.
Additional arguments required for calculation of skybright:
A1 - 1 for CIE clear, 2 for CIE overcast,
3 for uniform, 4 for CIE intermediate
A2 - zenith brightness
A3 - ground plane brightness
A4 - normalization factor based on sun direction
A5,A6,A7 - sun direction
cosgamma = DxA5 + DyA6 + Dz*A7;
gamma = Acos(cosgamma); { angle from sun to this point in sky }
zt = Acos(A7); { angle from zenith to sun }
eta = Acos(Dz); { angle from zenith to this point in sky }
wmean(a, x, b, y) : (ax + by) / (a + b);
skybr = wmean((Dz+1.01)^10,
select(A1, sunnysky, cloudysky, unifsky, intersky),
(Dz+1.01)^-10, A3);
sunnysky = A2 * (.91 + 10exp(-3gamma) + .45cosgammacosgamma)
* if( Dz - .01, 1.0 - exp(-.32/Dz), 1.0) / A4;
cloudysky = A2 * (1 + 2*Dz)/3;
unifsky = A2;
intersky = A2 * ( (1.35sin(5.631-3.59eta)+3.12)sin(4.396-2.6zt)
+ 6.37 - eta ) / 2.326
exp(gamma-.563*((2.629-eta)*(1.562-zt)+.812)) / A4;
