[clarified] is the solar radiation analysis summation method correct?
according to the explain for the ladybug_radiation analysis component, the total radiation is calculated by the “sum of irradiance for each test point [kWh/m2]” multplies the “sum of patch area represented by each test point [m2]”.
I’m thinking if this is correct because the area for each surface patch represented by a test point may not be the same depending on the meshing of the building envelope.
I think the correct way of total solar radiation calculation should be the mass addition of “irradiance for each test point multiplies the area the test point associated with”.
Please kindly verify if my suggestion is correct!
Thank you!
Hi Grasshope,
Exactly for the same reason that you said that the area of the surfaces are not the same we need to multiply the values by area before adding them together. Imagine you have a horizontal surface with area of 20 m2 vs another surface with area of 10 m2. If you use different grid sizes the result will stay the same in the current approach (and that’s what the right value) but with your approach the value will be drastically effected by the grid size. For an extreme case think of a single test point in the center of both surfaces. They will show the same total values.
Mostapha
Dear Mostapha, thank you for your reply!
I’m not sure if I explained my point clearly. So, let’s use the following example of a building surface with two patches after subdivision for simulation, each having a test point at its centroid with an irradiance reading.
So, shoudn’t the total radiation energy for this surface be calculated as the sum of the radiation energy for patch A (32=6kwh) and that for patch B (51=5kwh) which is 11kwh?
The result for the current summation method used in Ladybug is (3+5)(21)=24kWh.
As far as I understand, irradiance is an “intensity” variable, so, we need to multiply it by area to get the value of the absolute amount of radiation energy for a surface.
Please kindly comment.
Hi Grasshope, The first approach is what Ladybug does under the hood. I think we both agree that’s the right way to do it. I made an example that should show how does it work under the hood.
radiation_analysis_cumulative_results.gh (378 KB)
Ah! Got you… The explanation on the component is wrong. I will get it fixed. Sorry that I didn’t read it carefully. The calculation method is accurate though.
Very Sorry. This is my mistake. I didn’t even realize how wrong the description was when I wrote it. Thanks for fixing this, Mostapha.
-Chris
Dear Mostapha and Chris,
Thank you very much for your clarification!
I’m glad that we agree with the rationale of calculation used by Ladybug under the hood!
Thanks, again!
