I am working with a group of designers how are responsible for designing a smart neighbourhood. The Neighbourhood design has cluster housing. There are nine clusters and each cluster has 8 houses. Which looks like the following
Hi @kmhalam, Can you add more details one what are you exactly looking for? I’m not sure I will know the answer but that should help others on the forum to be able to help you.
@mostpaha: The idea is to make neighbourhood energy neutral. The houses would be connected to indoor lighting control systems. We would like to maximize daylight penetration in the houses. I was looking for co-housing or cluster housing example and wanted to know the challenges faced by designers while designing such neighbourhood.
