I’ve been trying to output CO2 carbon emissions from electricity in Cairo, Egypt.
I know this has not been available in Honeybee-Legacy, so I used the additional strings as follows:
Output:EnvironmentalImpactFactors,
RunPeriod; !- Reporting_Frequency
0.3, !- District Heating Efficiency
3.0, !- District Cooling COP {W/W}
0.25, !- Steam Conversion Efficiency
80.7272, !- Total Carbon Equivalent Emission Factor From N2O {kg/kg}
6.2727, !- Total Carbon Equivalent Emission Factor From CH4 {kg/kg}
0.2727; !- Total Carbon Equivalent Emission Factor From CO2 {kg/kg}
FuelFactors,
NaturalGas, !- Existing Fuel Resource Name
m3, !- Units of Measure
, !- Energy per Unit Factor
0.01, !- Source Energy Factor {J/J}
, !- Source Energy Schedule Name
50.23439, !- CO2 Emission Factor {g/MJ}
, !- CO2 Emission Factor Schedule Name
3.51641E-02, !- CO Emission Factor {g/MJ}
, !- CO Emission Factor Schedule Name
9.62826E-04, !- CH4 Emission Factor {g/MJ}
, !- CH4 Emission Factor Schedule Name
4.18620E-02, !- NOx Emission Factor {g/MJ}
, !- NOx Emission Factor Schedule Name
9.20964E-04, !- N2O Emission Factor {g/MJ}
, !- N2O Emission Factor Schedule Name
2.51172E-04, !- SO2 Emission Factor {g/MJ}
, !- SO2 Emission Factor Schedule Name
3.18151E-03, !- PM Emission Factor {g/MJ}
, !- PM Emission Factor Schedule Name
2.38613E-03, !- PM10 Emission Factor {g/MJ}
, !- PM10 Emission Factor Schedule Name
7.95378E-04, !- PM2.5 Emission Factor {g/MJ}
, !- PM2.5 Emission Factor Schedule Name
0, !- NH3 Emission Factor {g/MJ}
, !- NH3 Emission Factor Schedule Name
2.30241E-03, !- NMVOC Emission Factor {g/MJ}
, !- NMVOC Emission Factor Schedule Name
1.08841E-07, !- Hg Emission Factor {g/MJ}
, !- Hg Emission Factor Schedule Name
2.09310E-07, !- Pb Emission Factor {g/MJ}
, !- Pb Emission Factor Schedule Name
0, !- Water Emission Factor {L/MJ}
, !- Water Emission Factor Schedule Name
0, !- Nuclear High Level Emission Factor {g/MJ}
, !- Nuclear High Level Emission Factor Schedule Name
0; !- Nuclear Low Level Emission Factor {m3/MJ}
FuelFactors,
Electricity, !- Existing Fuel Resource Name
kg, !- Units of Measure
0.293, !- Source Energy Factor {J/J}
168.33317, !- CO2 Emission Factor {g/MJ}
4.20616E-02, !- CO Emission Factor {g/MJ}
1.398578E-03, !- CH4 Emission Factor {g/MJ}
4.10753E-01, !- NOx Emission Factor {g/MJ}
2.41916E-03, !- N2O Emission Factor {g/MJ}
8.65731E-01, !- SO2 Emission Factor {g/MJ}
2.95827E-02, !- PM Emission Factor {g/MJ}
1.80450E-02, !- PM10 Emission Factor {g/MJ}
1.15377E-02, !- PM2.5 Emission Factor {g/MJ}
1.10837E-03, !- NH3 Emission Factor {g/MJ}
3.72332E-03, !- NMVOC Emission Factor {g/MJ}
3.36414E-06, !- Hg Emission Factor {g/MJ}
0, !- Pb Emission Factor {g/MJ}
2.10074, !- Water Emission Factor {L/MJ}
That worked properly, and I got a .Meter file in the results file containing all the gases emissions and their carbon equivalent.
Now when I tried to do the same with HB 1.7, it did not work. I figured out about the Title 24 weather files and the supporting TDV files to add as schedules for fuel prices, yet still that did not help. Here’s the additional strings in HB 1.7 (I copied the TDV file into OS/Energyplus directory, so it is reading the file correctly):
Schedule:File,
elecTDVfromCZ06com, !- Name
Any Number, !- Schedule Type Limits Name
DataSets\TDV\TDV_2008_kBtu_CTZ06.csv, !- File Name
1, !- Column Number
4, !- Rows to Skip at Top
, !- Number of Hours of Data
, !- Column Separator
, !- Interpolate to Timestep
60; !- Minutes per Item
Schedule:File,
natgasTDVfromCZ06com, !- Name
3, !- Column Number
4; !- Rows to Skip at Top
! The source energy is based on TDV factors from the DataSets\TDV files
! the remaining numbers are from USA EPA AP-42 Chapter 1
! External Combustion Sources
FuelFactors,
natgasTDVfromCZ06com, !- Source Energy Schedule Name
! the remaining numbers are from USA national average based on eGRID, EIA 1605, AirData
FuelFactors,
elecTDVfromCZ06com, !- Source Energy Schedule Name
I hope you could help with that,
Cheers,
Yasser
