Could you please tell me what might cause this color inconsistencies in the radiation analysis mesh?
I checked the mesh and i see no problems with it.
Thank you!
Thank you!
Hi,@Bogdan According to my experience, you should check the direction of this surface.
And the image you showed has not any color of analysis result.
Hi @minggangyin
UnifyMeshNormals reports:
All face normals are already oriented in the same direction.
Here’s another example:
Try to slightly increase distance_from_base input. Looks like a number of test points are behind the mesh faces.
