Hey @masoome ,
There was a bug in the last release when you tried to run the comfort maps for shortrun periods. Removing the run period or upgrading to the latest development version of the plugin with the LB Versioner should fix this. More info here:
Also, don’t mix Legacy and LB components in the same script:
Use the equivalent LBT component
