Hi there,
I’m currently trying to model a simple radiant system (specifically, a thermoactivated slab) in HB using the radiant HVAC system following this topic, but I’m facing some challenges.
I have two questions:
- When setting the setpoints for the HB radiant HVAC system, how can I specify the setpoint as the operative temperature? Does the program automatically detect and account for this?
- Is this type of system included in the MRT calculations for both PMV and UTCI comfort maps? For some reason, this doesn’t seem to be working in my case. I have run several test but the radiant temperature does not change.
Comfort map with radiant system Test.gh (177.1 KB)
For context, I’m only using the radiant surface for cooling.
Thanks
