Hello
For a university project, I’m creating an canopy for an outdoor space and want to use Ladybug’s Comfort Shade Benefit Evaluator to find the necessary area of the canopy.
But the “shadeNetEffect” is always zero, giving no results. I’ve tried to run this case study from github of a bus stop in New York and it’s not giving the results it was supposed to show. I guess the problem is not the algorithm, since I’m following the instructions. The other components are showing normal results.
The image below is showing the case study, that is supposed to be correct, but is having the same error as my project.
I have installed Ladybug 0.0.69, Honeybee 0.0.66 and the optional installations.
–Edit–
This is the error message that comes in everyline of the output “out” of the shadeNetEffect component, even with correct inputs:
ValueError('need more than 0 values to unpack',)
Also, every line from the outputs “shadeHelpfulness” and “shadeHarmfulness” comes as zero
I’m using Rhino 7
