Hi everyone,
I want to model a double skin facade in the honeybee, I used the example on “hydrashare”.
The use of a double skin facade should basically reduce energy consumption, but in this example comparing double-skin facade with single skin results shows a sharp increase in energy consumption.
I changed the model a bit to make it a single skin, the total energy consumption of the single skin model is 314 (kWh/m2) and in the double skin model, the total energy consumption is 2592 (kWh/m2)! its makes no sense!
Is there anything I missed?
thank you for helping!
