Hi, I am trying to compare how the thermal comfort of a room changes if i change the south facade (variables being the window sizes, facade shape, window orientation, shading elements, etc.). In total, i have 25 different iterations that I need to compare. How do I go about comparing these, given that each adaptive thermal comfort map generates a thermal map that is visualized as a grid?
I would like to create a matrix that has a single numeric value for thermal comfort for each iteration. Is that possible or should it be represented as a bar graph?
Thanks
